Perform this procedure to clear information about Energy Efficient Ethernet (EEE) statistics for all ports on a switch, or for a specific port.
Use the data in following table to use the clear energy-saver eee stats command.
Variable |
Value |
| port |
Specifies one or more ports. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
